How do I add a calendar to my dashboard?
Did you know that any iCal compatible URL can be used?
As long as the calendar is published as an iCal file via the web or via a webcal:// endpoint, you should be able to use it as a calendar resource.
Try clicking the 'Help' button when creating a calendar for a variety of calendar recommendations. You can click on any of the Popular Calendar options to automatically configure that particular calendar.
Add Calendar to Dashboard
- Open your desired dashboard
- Tap the `...` in the bottom right corner and select Edit
- Tap the green '+' button to add an item
- Expand the Calendars section and select your calendar to add it to your dashboard
You can find more information about customizing your calendar display and the associated refresh intervals in the following article:
Customizing Your Calendar View and Understanding Refresh Intervals
Calendar Types
Month Calendar
Agenda Calendar
Other Notes
The font size for the calendar is determined by the relative size of a 1x1 tile on the dashboard. When using one of the default 'Number of Columns' settings for a Scalable dashboard the font should be a reasonable size, but if the number of columns has been increased or decreased significantly, then the font size might be too small or too large. You can use Custom CSS to adjust the size of your calendar content as desired:
