How to use Apple iCloud Calendars in Calendar Tiles
SharpTools.io dashboards support a variety of calendars via the iCal standard, including Apple iCloud Calendars. This article explains how to get an iCal compatible URL from Apple's iCloud for SharpTools.
- Login to iCloud
- Click on Calendar
- Click on the Sharing icon next to the calendar
- Ensure the box next to Public Calendar is checked
- Click Copy Link to copy the iCal URL
- Open the SharpTools.io Manage Resources screen for Calendars
- Click Create Calendar
- Enter a name for the calendar and the URL you copied from the Secret Address in iCal format field
- Click Create
Success! You've now linked your iCloud Calendar as a valid calendar source in SharpTools. To use the calendar in your dashboards, edit your dashboard and add the newly created calendar.
You can find more information about customizing your calendar display and the associated refresh intervals in the following article:
Customizing Your Calendar View and Understanding Refresh Intervals
General information about adding a calendar to your dashboard can be found here:
