How to use Office 365 in Calendar Tiles
SharpTools.io dashboards support a variety of calendars via the iCal standard, including Office 365 Calendars. This article explains how to get an iCal compatible URL from Microsoft Office 365 for SharpTools.
  1. Login to Office 365 Calendar Settings
  2. Select the calendar you wish to use from the Select a Calendar drop down
  3. Select your desired permissions from the Select Permissions drop down
  4. Click Save
  5. Copy the URL shown next to ICS
  6. Open the SharpTools.io Manage Resources screen for Calendars
  7. Click Create Calendar
  8. Enter a name for the calendar and the URL you copied from the ICS field
  9. Click Create
Success! You've now linked your Microsoft Office 365 Calendar as a valid calendar source in SharpTools. To use the calendar in your dashboards, edit your dashboard and add the newly created calendar.
