How do I get started with SharpTools.io?
SharpTools.io is a web application that enables you to view, control, and automate your smart home. This is done through two primary features:
- 1
Dashboard: Provides an intuitive way to view status and control your smart home devices from any modern browser. Easily accessible from mobile phones and frequently used in dedicated tablet displays.
Learn More - 2
Rule Engine: A simple but powerful automation tool that enables you to create automation rules in a visual flow editing interface. Rules can be triggered based on time schedules, device events, hub events, conditions and more.
Learn More
Connecting Smart Devices
We'll start by authorizing access to your smart home devices.
At the time of writing this article, SharpTools.io supports the SmartThings, Homey, Hubitat, and Home Assistant smart home platforms. Each of these platforms connects with hundreds of devices across a variety of protocols. For more information, see the Compatible Devices article.
Do you have suggestions for other smart home platforms we should support? Send a message to support@sharptools.io with your suggestion.
High Level Approach
- Sign into SharpTools.io
- Authorize your smart home devices
- Create a new dashboard and/or automation rule
Detailed Steps
- 1
Navigate to https://sharptools.io/user
Note: If you haven't signed-in yet, login using one of the presented options (Google, Email/Password, Phone) - 2
After logging in, you should arrive at the the User page.
Learn more about the User Page - 3
Tap "Manage Connections" and the platform you want to connect to your SharpTools account.
- 4
You should be redirected to a login for your Smart Home platform or prompted with details on how to proceed. When selecting SmartThings or Hubitat, be sure to enter your SmartThings/Hubitat credentials when prompted (not SharpTools credentials) and complete the sign-in
- 5
After you have signed in, select your location from the drop down list, and check the boxes for the devices you want SharpTools to be able to access.
Note: If you add new devices to your SmartThings, Homey, Hubitat, or Home Assistant hub in the future, be sure to complete the Manage Connections process again to grant SharpTools access to the new devices.
- 6
- Scroll down and tap Authorize at the bottom of the authorization screen
- 7
Now you should be redirected back to SharpTools.io page with the following success message displayed.
After seeing the 'Congrats!' screen, it may take a few moments to sync devices over in the background depending on how many devices were authorized.
If you are having difficulty authorizing devices on Hubitat, refer to the Hubitat Authorization Troubleshooting Steps
Congratulations! You've connected your devices to SharpTools - you are now ready to create your custom dashboard or automation rule!
If you have any question or need any help, feel free to contact support@sharptools.io.
