Why don't my things show up?
In order for SharpTools to have access to your smart devices, you'll need to authorize access to them. If you add new device to your smart home hub, you may need to proceed through these steps again to authorize new devices.
  1. Navigate to your SharpTools.io User Page
  2. Tap Manage Connections
  3. Select your desired platform and follow the on-screen instructions
  4. If your hub prompts to select which devices you want to authorize, make sure to check the boxes next to any new devices you'd like you add.
Not seeing one of your Hubitat devices in the authorization list? You may be able to manually authorize the device for Hubitat if it implements at least the Sensor or Actuator capabilty.
If you are having trouble authorizing your Hubitat hub, try the troubleshooting steps in the Hubitat Authorization Troubleshooting document.
