How to Reset Password
If you've opted to use an email/password sign-in with SharpTools, you may be wondering how to reset your password.
When you attempt to login with an invalid password, the system will show a Reset Password button in the bottom-left corner of the login form which you can use to reset your password. Once you submit the Reset Password form, you will be sent an email with a special link that enables you to reset your password.
If you don't see the password reset email in your inbox after submitting the form, check your Spam folder to make sure it didn't end up there.
