How do I set up Twilio SMS?
Twilio is a global communications platform with international SMS support.
You are responsible for any billing and payments with Twilio. We strongly recommend leaving Auto Recharge disabled on your Twilio account to prevent any unintended large charges.
How to Connect Twilio SMS to SharpTools
Register Twilio Account + Phone Number
- Create a Twilio account
- While logged into Twilio, navigate to the Phone Numbers search page
Search for and purchase an SMS enabled phone number
Note: Make sure the phone number you purchase has an icon under the SMS field.
If you already have an existing Twilio SMS enabled phone number from another project, feel free to use it.
Note that while you are on a Twilio trial, you can only send SMS messages to phone numbers that you've verified and messages may have trial text appended to them. Upgrade your Twilio account in order to removed these restrictions.
Connect Twilio to SharpTools
- Open your SharpTools.io user Page
- Tap the Manage Connections button
- Select Twilio SMS from the list
Copy your SID and Auth Token from your Twilio console into the Account SID and Auth Token fields in SharpTools
Note: You may need to click 'view' to copy your Auth Token
Copy your SMS enabled phone number from the Twilio Phone Numbers page into the 'From Number' field
Press Save to complete the process
