Homey Flows
There are two approaches that are commonly used to execute Homey Flows from SharpTools:
1. Create a Virtual Button and use that as a trigger for your Flow (reference)
2. Use the Homey Flows Custom Tile in SharpTools (community post)
The first option works in both dashboards and rules whereas the second option is specifically designed for dashboards.
