Custom Date Format in Super Tiles
The Date/Time item within Super Tiles supports a variety of formatting 'tokens' for creating a custom date/time string. While the built-in presets within the drop-down provide a quick at-a-glance reference, the full list of options is documented below.
Looking for the full list of date formats that are available to Rule Expressions? Check out the Date Formats in Rule Expressions article.
| Format | Output | Description |
YY |
18 | Two-digit year |
YYYY |
2018 | Four-digit year |
M |
1-12 | The month, beginning at 1 |
MM |
01-12 | The month, 2-digits |
MMMM |
January-December | The full month name |
D |
1-31 | The day of the month |
DD |
01-31 | The day of the month, 2-digits |
Do |
1st 2nd ... 31st | The day of the month with ordinal |
dddd |
Sunday-Saturday | The name of the day of the week |
H |
0-23 | The hour |
HH |
00-23 | The hour, 2-digits |
h |
1-12 | The hour, 12-hour clock |
hh |
01-12 | The hour, 12-hour clock, 2-digits |
m |
0-59 | The minute |
mm |
00-59 | The minute, 2-digits |
s |
0-59 | The second |
ss |
00-59 | The second, 2-digits |
A |
AM PM | Post or ante meridiem, upper-case |
a |
am pm | Post or ante meridiem, lower-case
Note that this is a subset of the formats supported by the Rule Engine. This means many formats like d, dd, ddd, SSS, Z, ZZ, and others are not supported within the Date/Time item within Super Tiles even though they are supported within Rule Engine expressions.
Special characters like spaces, dashes, periods, commas, and slashes are preserved. Square bracket characters should not be used as these are reserved for future use.
