General Functions in Rule Expressions
Math Features
abs(input)
Returns the absolute value of an input number.
abs(-20) #// returns: 20
ceil(input)
Rounds up and returns the smaller integer greater than or equal to the given number.
ceil(9.1) #// returns: 10
floor(input)
Rounds down and returns the largest integer less than or equal to the given number.
floor(9.9) #// returns: 9
round(input[, precision])
Rounds a given number to the nearest integer, or to the nearest number of decimals when given a precision.
round(9.9) #// returns: 10 round(9.98) #// returns: 10 round(9.88, 1) #// returns: 9.9
toFixed(input[, digits])
Takes a numeric input along with a number of digits to display and formats the number as a string with the specified number of digits (rounding if necessary). Note the distinction from round() in that toFixed() outputs a string and retains the exact number of digits specified, zero-padding if necessary.
toFixed(12.345, 2) #// "12.35" toFixed(12.345, 0) #// "12" toFixed(120, 2) #// "120.00"
random([min, max])
Returns a random number between 0 and 1. When provided with a min and max argument, returns a random number between min and max.
random() #// returns: 0.98 random(0, 100) #// returns: 78.34 round(random(100, 200)) #// returns: 152 randomInt(100, 200) #// returns: 152
randomInt() above which can be used as an alias / shorthand for getting a random integer value
Boolean Logic
and(a, b)
Returns true if a and b are both true
and(1 > 0, true) #// returns: true 1 > 0 and true #// returns: true (true) and (false) #// returns: false
or(a, b)
Returns true if either a or b are true
or(0 >1, true). #// returns: true 0 > 1 or true #// returns: true (true) or (false) #// returns: true
not(input)
Flips a boolean value of a given input
not(true) #// returns: false not(false) #// returns: true not(1 > 0) #// returns: false
Arrays
count(array)
Returns the count of the number of items in an array (especially useful when combined with filter)
count([1,2,3]) #// returns: 3 count(filter([1,2,1,12,9,11], x > 10)) #// returns: 2
filter(array, expression)
Filters a given array based on the boolean expression being applied to each element of the given input array.
filter([1,2,1,12,9,11], x > 10) #// returns: [12, 11]
map(array, expression)
Create a new array with the results of the expression applied to each element of the array
map([1,2,3], x * 2) #// returns: [2,4,6]
pickRandom(array)
Selects a random item from the array
pickRandom([1,2,3]) #// returns: 2 pickRandom(['foo', 'bar', 'baz']) #// returns: 'foo'
join(array, joiner)
Concatenates elements of the array together using the given joiner.
join(['foo', 'bar', 'baz'], ', ') #// returns: 'foo, bar, baz' join(['foo', 'bar', 'baz'], '-') #// returns: 'foo-bar-baz'
Objects
objectKeys(object)
Outputs an array which contains the key names of the top-level properties of the input object
objectValues(object)
Outputs an array which contains the values of the top-level properties of the input object
obj = { "first": "value1", "second": 2, "third": {"foo": "bar"}}
objectKeys(obj) #\\ Output: ["first", "second", "third"]
objectValues(obj) #\\ Output: ["value1", 2, {"foo": "bar"}]
See example usages in the community.
General String Manipulation
parseJson(input)
Parse and input string as a JSON object
parseJson("2") #// returns: 2
parseJson("\"test\"") #// returns "test"
parseJson("[1,2,3]") #// returns [1,2,3]
parseJson("[\"foo\", \"bar\"]") #// returns: ["foo", "bar"]
parseJson("{\"value\": 2}") #// returns: {"value": 2}
stringify(input)
Convert a JSON object (or number/string) into a JSON string
stringify(2) #// returns: "2"
stringify("test") #// returns '"test"'
stringify([1,2,3]) #// returns "[1,2,3]"
stringify(["foo", "bar"]) #// returns: '["foo", "bar"]'
stringify({"value": 2}) #// returns: '{"value": 2}'
concat(a, b, [c, d, ...z])
Joins two or more strings together
concat("foo", "bar") #// returns "foobar"
concat("Hello", " ", "World") #// returns "Hello World"
urlEncode(input)
Converts a given input string to its URL encoded equivalent
urlEncode("Mañana") #// returns: "Ma%C3%B1ana"
Content Checks
isEmpty(input)
Checks if a given input is ‘empty’. Returns true for an input string that is null or blank "" , an array with no items, or a number that is 0. Otherwise returns false
equalText(left, right)
Checks if a given input string on the left exactly matches the input string on the right . Returns true for a match. Otherwise returns false
contains(input, searchTerm)
Returns true if an input contains a given searchTerm
indexOf(input, searchTerm)
Returns the zero-based ‘index’ (position) of the first occurrence of a given searchTerm within an input string.
indexOf("Hello World", "l") #// returns: 2
lastIndexOf(input, searchTerm)
Returns the zero-based index (position) of the last occurrence of a given searchTerm within an input string.
lastIndexOf("Hello World", "l") #// returns: 9
startsWith(input, searchTerm)
Returns true if the input string begins with the given searchTerm
endsWith(input, searchTerm)
Returns true if the input string ends with the given searchTerm
Substrings
replace(input, searchTerm, replacement)
Replaces the searchTerm with the replacement value if found in the input
replace("Hello World", "World", "Universe") #// result: "Hello Universe"
replace("Hello World", "Hello ", "") #// result: "World"
replace("Hello, World", ",", ":") #// result: "Hello: World"
split(string, separator)
Splits a given string using the separator into an array of substrings.
split("Hello - World", " - ") #// returns: ["Hello", "World"]
mid(input, start, length)
Given a zero-based start position, returns the remaining length of characters. If length is omitted, returns all remaining characters.
mid("Hello World", 6) #// returns: "World"
mid("Hello World", 1, 4) #// returns: "ello"
mid("Hello World", -5) #// returns: "World"
Note that you can use a negative start index which counts from the end of the string instead of the beginning
substring(input, start, end)
Returns a substring from a given input string starting at the zero-based start position and ending at the zero-based end position. If end is omitted, returns all remaining characters.
Note that this is different from mid() as it requires an
endindex rather thanlength
substring("Hello World", 0, 5) #// returns: "Hello"
substring("Hello World", 6) #// returns "World"
left(input, length)
Returns the first length characters from an input stringright(input, length)
Returns the last length characters from an input string
Remove Whitespace
trim(input)
Removes all whitespace from before and after a given input string
trimLeft(input)
Removes all whitespace from before a given input string
ltrim(input)
Alias for trimLeft()
trimRight(input)
Removes all whitespace from after a given input string
rtrim(input)
Alias for trimRight()
Change Case
upper(input)
Returns an input string formatted as all 'UPPER CASE'
lower(input)
Returns an input string formatted as all 'lower case'
title(input)
Returns an input string formatted as 'Title Case'
Conditions / Ternary Expression
condition ? trueExpression : falseExpression
Given a condition, returns the result of either the 'true expression' or 'false expression' based on the result of the condition evaluation. This could be read as 'If condition is true, then return the true expression, else return the false expression'
equalText($switchState, "on") ? "active" : "inactive" #// conditionally convert a state factor = (X > 0) ? 1 : -1 #// determine if you want a positive or negative factor isEmpty(X) ? "default" : X #// default a value if source value is not set
Ternary expressions can also be chained together
condition1 ? value1 : condition2 ? value2 : condition3 ? value3 : value4
This is roughly equivalent to the following logical statement (the example below is not valid expression syntax, but is how you might describe the above chained ternary expression in words):
if (condition1) then value1 else if (condition2) then value2 else if (condition3) then value3 else value4
